BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Spare tire (when you have non run flat tires)
      08-14-2016, 06:55 AM   #23
Pristineship
48
Drives: F48 X1 X line sDrive 20i
I work for R&D Continental, I can explain to you at length why all RF tires will puncture more easily, but let's stick to the easy "explain like you're 5" - an 18" wheel with optimal air pressure is "touching" the ground with about as much space as a soccer ball. Now, if you put your foot down on such ball, it will deform and the space in direct contact with the ground could easily quadruple for a fraction of second.
Basically the same thing happens with a tire if you hit a pothole. With a runflat tire, because of reinforced sidewall (normal tires have usually 5 to 7 rather thin wires used as reinforcement, RFT have a very complicated metal form that you wouldn't be able to deform with your own body weight. If a RFT tire hits a pothole, you have a fraction of space to "spring" the sudden pressure, so if normal tire can basically use about a third of the tire to bend and compress, you have 20% of that with an RFT, the pressure on the material is significantly higher, and the reinforced sidewall itself if damaged can cause a tear, internally, you could not even notice the tire is damaged.
RFT, and especially tires over 18" are referred in rubber business as "printing money" tires, but nobody, absolutely nobody who understands what RFTs really are is putting RFT on their car.
You can praise them all you want, but they simply are a very expensive piece of equipment that is not worth the extra.
      08-14-2016, 01:49 PM   #24
jsdh89j9ijkL
65
Drives: motorcycle
heh, you need to keep that quiet.
oops.
Never had a RFT, never will.
      12-25-2016, 08:24 PM   #25
goodysgotacuda
Drives: X1
Has anyone added the spare tire kit/tools to a RFT car? If so, where dido you buy the parts? Do you have a list of part numbers?
I would like to add a spare since we do many long distance runs and don't want to be out of range for the RFT or be concerned if the closest shop has the tire in-stock.
      12-26-2016, 05:34 AM   #26
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
I've added the spare. I simply purchased the space saver rim from a dealer and then bought the relevant tyre from tire rack.com. The other bits -- a wheel lug wrench and scissor jack I purchased from an auto parts store. Everything is tied down in the underfloor along with other bits and pieces. All up cost...around $250.
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      12-27-2016, 05:52 PM   #27
zznalg
12
Drives: 2014 X1 xDrive28i
Ditto. I'd like the same info for 18" wheels, for the same reason. My dealer is quoting me $650 USD for the spare tire kit!
      12-27-2016, 09:07 PM   #28
goodysgotacuda
Drives: X1
Pretty much in-line with these guys once you ship it.
https://www.getbmwparts.com/partloca...catalogid=4462
I think I can buy the tire/wheel for $250/shipped and then just come up with the other pieces locally. I bet I can find a way to tie it down.
      12-28-2016, 04:32 PM   #29
zznalg
12
Do you have a part number for the rim you bought from BMW? As well as a description of the other parts you purchased? What size was your space saver rim? This info will be very helpful. Thanks much.
      12-28-2016, 07:56 PM   #30
ttimbo
ttimbo's Avatar
282
The BMW part number for "Compact spare wheel, steel, black size 3.5BX17 ET:18" is 36116851507 (as at April 2016)
I purchased from Tirerack.com a Kumho Spare T121 size T135/90R17 to suit. The original wheel lug bolts can be used. I then purchased a generic scissor jack (2000Kg) from an autoparts store, along with a generic lug nut wrench.
This is the only spare wheel BMW sells for the X1, AFAIK. The wheel and tyre combination (135/90x17" has *approximately* the same rolling diameter as 225/55x17", 225/50x18" and 225/45x19", which are the X1 wheel size options.
      12-29-2016, 06:37 AM   #31
E90Fleet
South Africa
1312
Drives: BMW
F48 X1 Spare Rim
Part numbers:
1. 36 11 6 851 507
Tire used by BMW
Maxxis M9502
135/90/17 104M
Part number: 36 12 2 407 369
BMW if you are reading, I need a job, Please.
      12-29-2016, 06:45 AM   #32
E90Fleet
South Africa
1312
Drives: BMW
F48 Jack and storage parts
1 Ablage Notrad 71106857380
2 Lifting jack storage partition 71106878508
only in conjunction with
-- Velcro fastener 71106878510
4 LIFTING JACK 71126885765
-- Set of felt strips SET 51452353024
05 Wheel-nut wrench 71126779731
06 Chock 71121507292
07 Actuating ratchet for vehicle jack 71126769151
08 Bracket 36106857382
09 Cover 36106857383
10 Hex bolt with washer M6X20 07119904527
11 Wing screw M8X68 1 07119908728
12 Hex bolt M8X20- 8.8-ZNS3 07119906119
      12-29-2016, 06:48 AM   #33
E90Fleet
South Africa
1312
Drives: BMW
Picture from Bimmerpost member:
Missing number 2 "Lifting jack storage partition" that is held by the velcro to the left of the wheel
      12-29-2016, 03:42 PM   #34
AUS_Tin_Pusher
AUS_Tin_Pusher's Avatar
Australia
23
Drives: F48 X1 xDrive25i
Outstanding E90Fleet - thanks.
      12-29-2016, 04:11 PM   #35
MikeG12
65
Drives: 2020 X3M40, 2000 Z3M, 2017 X1
For those who purchased the spare tire/wheel, how did you hold it down in the compartment? I have one but haven't fastened it down yet.
      12-29-2016, 04:29 PM   #36
hart4bmw
hart4bmw's Avatar
Netherlands
80
Drives: BMW X1 Sdrive20i (2016)
I've thrown away
For more space !
      12-29-2016, 05:36 PM   #37
E90Fleet
South Africa
1312
Drives: BMW
I would think the screw point for the wing nut is there on all cars, but those that dont come with the option from the factory have a trunk lining without the hole exposing it.
You could remove the lining and see if just a small home in the right place would expose the screw point
The bracket ( no 8 in the picture above) is also required for a secure fit
      12-30-2016, 11:33 AM   #38
mustardman
15
Drives: 2017 X1
Is there enough depth in the trunk well there to accommodate a full size spare?
      12-30-2016, 02:04 PM   #39
Vogit
93
Drives: X1 xDrive 20D xLine
Unfortunately not without raising the false floor
      01-23-2017, 06:58 AM   #40
Max1Factor
28
Drives: X1 xDrive20i M Sport
I'm getting the 19" wheels and they come with RFT which I'll change out when worn to non-RFT. So I'm thinking I should order the Space Saver spare as factory build then store or just use for some journeys. Question is when jack and wheel are removed do you get left with a nice flat under floor space ? Thanks.
Max
      01-23-2017, 04:27 PM   #41
Vogit
93
Max
Yes you do, although you might want to remove the bracket on the front edge ( See photos in earlier post).
      01-24-2017, 09:12 AM   #42
Max1Factor
28
Thanks Vogit. Just added in time. Max
      08-08-2018, 12:56 AM   #43
civciv
Drives: X1 F48 Med. Blue
Can I use 145/80 18 (5×112) size as spare tire? It is from a VW vehicle.
      08-11-2018, 10:36 PM   #44
DrPeteF48
Drives: 2017 F48, Jet Black
Purchased from my local dealer, but they ship too...
https://parts.bmwnorthwest.com/a/BMW...1_0828.html#01
I ordered the actual wheel from Bimmerzone because they ship a pre-mounted wheel/tire combo.
In terms of the install, all it took was removing the little tool holder in the front of the storage compartment and replacing it with the little metal L-bracket that holds the spare down. This requires cutting a little slit in the liner but isn't tough.
I got the separate foam block for the jack as well, though it looks like there may be a spot for the jack in the tray that goes inside the wheel too.
