BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Bimmercode Adventure
      12-26-2018, 01:39 PM   #89
kitkit201
Drives: BMW X1 2018
Help!! Coding adventure
Hi I'm new here and starting my "coding" adventure.
I bought 2 sets of these lamps (4 bulbs total) https://www.amazon.com/1156-P21W-Phi.../dp/B00O3GSC2A
I'm getting errors on the dashboard after coding through Vgate Bluetooth 4.0 and Bimmercode app.
I've replaced the outside brake lamp and inside tailgate brake lamp with these and i'm getting a "Left two-stage brake lamp malfunction" and "Right two-stage brake lamp malfunction".
I believe the outside one works fine as I turned on the headlights and they come on. The inside one directly underneath the reverse light is not working?
I've tried many different combinations of coding to get it to go away, but i seem to not be able to.
Here is the link to the Bimmercode app and my settings https://www.flickr.com/photos/kitkit201/shares/DMV39P
Any help is appreciated. Thank you !
      12-29-2018, 03:23 AM   #90
X1604M
X1604M's Avatar
57
Drives: 2018, F48 28i
2018 BMW X1 F48  [0.00]
Smile
I will change break light cold and warm monitoring to (not active), and break light lamp to (LED). I don't know if you have tried that already.
      01-13-2019, 11:10 AM   #91
quaman26
Drives: 2017 BMW X1 Xdrive
Hi, I just started with bimmercode and I am just trying to automatically fold/unfold the mirrors when locking and unlocking but it is not working. I have power side mirrors. Can someone please advise what I can do to check? Thank you.
      01-13-2019, 11:58 AM   #92
Lucardos
No_Country
Drives: F48 X1 192HP MINERAL GREY
Fold mirrors with Comfort Closing is available in
»Body Domain Controller« BDC_01
put this option to Active.
same for unfolding.
also comfort closing needs to be activated
"Comfort Opening with remote control"
      01-13-2019, 03:48 PM   #93
quaman26
same for unfolding.
Thanks! That worked.
      01-13-2019, 04:00 PM   #94
quaman26
Originally Posted by Pewters View Post
Worked perfect........Thanks
Hi, I could not find this option in expert mode. Has it changed recently?
      01-14-2019, 03:41 AM   #95
pandauk
28
Drives: BMW X1
There was an update to the Bimmercode app, but I haven't used it since. Let me have a look the next few days, will come back to you. Did you look in the same place I highlighted last time?
Might be worth emailing the developer - he comes back to questions reasonably frequently.
      01-14-2019, 10:11 AM   #96
mikeyb74
mikeyb74's Avatar
121
Drives: G20 330ix M Sport
I've been seeing a couple of BMW shops offering Sport Plus coding onto a F48 that only has Sport. Would I be able to code Sport Plus with bimmercode? I see that you can code Sport Plus with F3x, F22/F23 cars. But did not see F48 listed.
      01-14-2019, 11:32 AM   #97
quaman26
Hi, yes I looked there and could not find it. I’ll try to email the developer. Thanks
      01-15-2019, 09:38 PM   #98
dizx
dizx's Avatar
Thailand
69
Drives: 2020 G20 330e
Alrighty, so a little update on the 5 blink indicator. Using the latest bimmercode, I set the tippblinken to 5 in the simple mode as I mentioned in my previous post. That by itself didn't work, and the indicator would only go 3 times. The option in iDrive was also 1 or 3 clicks, no option to select 5.
On my 2018 October production X1, additionally, I needed to go into expert mode in bimmercode, in the Headunit (HU_NBT_EVO) ECU, and then into 3000 HMI. In there, you want "5_FACH_TIPPBLINKEN". This option needs to be set to Aktiv.
This enables the 5 blink option in iDrive. I set the 5 blinks in iDrive and can confirm it works
Nice thx!
Current: 2018 X1 F48 & 2014 F20 116i. Before: 2009 BMW E90 320d LCI, 2008 E92 M3 &
MJE60678.00
      01-15-2019, 09:45 PM   #99
dizx
dizx's Avatar
Thailand
69
Have someone successfully coded "Configuration of driving modes" (menu with Drivetrain & Chassis / Drivetrain / Chassis) ?
      01-20-2019, 08:18 AM   #100
pandauk
28
Drives: BMW X1
Seems the latest app update has changed the layout and available options quite a bit. Did the guy come back to you?
      01-20-2019, 09:41 AM   #101
quaman26
Yeah, he did and he said BMW changed it so that option is not available anymore.
      01-24-2019, 01:31 PM   #102
RobinLegin
37
Drives: BMW X1 Xline 2i petrol
I don’t often go out when dark despite having my car just over a year. I noticed last night the headlights or spot lights do not stay on after I lock the car when it’s dark. I thought they were supposed to stay on for 30 seconds to allow me to get to my front door.
How can I go about fixing this? Will the dealer “kill” this when the car next goes in for service?
      01-24-2019, 01:32 PM   #103
RobinLegin
37
      01-24-2019, 03:23 PM   #104
CliveL
163
Drives: 2016 X1 F48 xDrive20i xLine
I think you have to flash the headlights after switching off the engine. Then they'll stay on for the length of time in the Settings menu for "home lights".
      01-25-2019, 07:13 AM   #105
Jmhockey1920
Drives: 2018 BMW X1
Is there a way to code my fog lights to turn on automatically like my headlights when I have the button on 'automatic'.? I know, I am too lazy to just press the fog lights on button every time
      01-25-2019, 08:19 AM   #106
gamesfrager
198
Drives: 2011 328i
Do you live in a constant foggy weather? If not; then please don't.
Appreciate 2
      01-25-2019, 10:10 AM   #107
Jmhockey1920
Drives: 2018 BMW X1
What is the code to get rid of that damn legal disclaimer deactivation that pops up every time I start my car? Also, since I did not get the navigation package, I have to pay in order to access Sirus XM, right?
      01-26-2019, 10:11 AM   #108
quaman26
It’s under head unit, Warning at Startup. You can disable it. As for SiriusXM, I don’t have navigation but I have SixiusXM on my 2017.
      01-26-2019, 10:13 AM   #109
quaman26
Hi, anyone know where I have to go to enable Easy Seat Entry?
      01-27-2019, 06:11 AM   #110
CliveL
163
These are the notes I made when enabling it with eSys...
SM2 - 3000 - EINAUSSTIEGSHILFE = nicht_aktiv (default) -> Modus_FA_SLV (Easy Entry seats)
SM2 - 3012 EAH - EAH_VERFAHRWEG_SLV_PHYS = Werte 00, 3C (60) -> 00, 32 (50) ("traverse" seat)
SM2 - 3012 EAH - EAH_SCHUTZFREIRAUM_HINTEN_SLV_PHYS = Werte 00, 64 (100)-> 00, 3C (60) ("rear space protection")
The module was SM2. The settings I changed to are to the right of the arrow (->), the original setting to the left.
Hope that helps!
