BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Random xdrive faults
      02-15-2024, 01:38 PM   #1
eniacs
Drives: X1 f48
Has anyone had a series of odd faults pop up?
I've had:
Washer level low (wasnt low)
Seat restraint system failure
Transmission major failure (engine wont start go to nearest service centre etc..)
Nothing happened on any of these messages and the car continued to work. Messages dissappeared and did not show anything on idrive (the warning triangle dissappeared).
Im thinking some kind of electrical fault:
Battery on its way out
Bad ground
Water getting in somthing
Is there any known faults which may cause this?
Thanks
      02-16-2024, 03:27 PM   #2
pinco000
pinco000's Avatar
165
Drives: F48
I had something similar where all possible errors would be thrown at me and then go. Then come back again and go.
I did a lot of digging around to pinpoint the issue.
In my case it was a usb memory stick kept plugged in for nearly two years. I unplugged it out of fun to see and it all stopped.
Not sure this is your problem though.
Try the battery voltage with engine on, off, alternator, grounding, weak sos batttery.
I checked all this before trying luck in desperacy.
