07-16-2021, 02:37 PM | #23 |
Occasionally frequent poster
3007
Rep 2,745
I don't know which wheel number I have, they are the honeycomb copies of the old TransAm wheels from the 70s.
They look fabulous, but they are a PITA to clean. I just bought a new sponge, it's a big one used for cleaning grout off of tile work and nice and soft. I'm hoping that it will be easier to get into all of those holes. I'll cut it in half first. I don't believe in this "spray on spray off" nonsense, as you have to get in there with a brush or a sponge or something and physically wipe off the dust. I also never, never use a pressure washer on anything related to the car, unless I'm trying to strip off paint. That's just too abrasive. FWIW, I use Griot's wheel cleaner, it works well, smells good (unlike Iron-X) and I believe is the same as P21S but a bit less expensive.
Current inventory:
F22 & G05 Cadillac CT5-V Blackwing w/3 pedals Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2) |
07-18-2021, 10:12 PM | #24 | |
1958
Rep 1,920
Drives: E92 M3
Sonax wheel cleaner would work better as a spray on. I only use a towel to wipe of the brake dust and it works well.
themnmd1691.00 |
07-19-2021, 07:04 AM | #25 |
201
Rep 341
Drives: M4 Competition
Another vote for Sonax...works great.
2011 335IS - Alpine White/Coral Red
2021 M4 Comp - Alpine White/Fiona Red |
07-20-2021, 09:28 PM | #26 | |
Leave the gun. Take the Canoli.
9195
Rep 7,772
Current: 2023 Santorini Blue ///M8 ||| 2023 X3 M40 --> 2025 X5 M60 (ordered)
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe |
07-20-2021, 09:34 PM | #27 |
9195
Rep 7,772
So at all of your recommendations I picked up some Sonax Wheel Cleaner Plus and Sonax Wheel Rim Shield. The directions say you have to put the wheel cleaner on a cool dry wheel and let it sit for 5min so I knew I couldn't go to the carwash as the wheels would have been hot from the drive there.
So, I pulled my car out into the driveway, sprayed on the wheel cleaner and let it sit. It did start to change color as they say. I think it would have done pretty well just like that, but I did get a long thin wheel brush that I allowed me to get back in the inner parts of the wheel (the large flat round area in the middle. I then filled up a garden sprayer with soft water from my sink and rinsed them off. Higher pressure would have been nice, but that would have been hard water from the hose (and my hose is also a hassle to get out as it lives in my garage when it's not connected). Dried the wheels and applied the Rim Shield and let the car sit for an hour as directed. The whole process took a little over 30min. The wheels are as close to looking factory clean fresh as they've ever been. Time will tell how effective the Rim Shield will be at either not having the brake dust stick as much and how easy it will wash off in the touchless wash. For the moment though, the wheels look AMAZING.
Retired: 2021 Enzian Blue ///M4 ||| 2018 ///M4 ||| 2017 ///M4 ||| 2014 435i ||| 2009 335i Coupe ||| 2007 335i Coupe Last edited by snareman; 07-21-2021 at 10:38 AM.. |
07-20-2021, 11:14 PM | #28 |
19
Rep 37
👍 Sonax works great. I would recommend trying it with a garden hose - usually I end up just spraying Sonax and then washing the the wheels with the hose. Finally do a light second round on the sections missed. This gets most of the wheel without too work ( 5-10 minutes or less ). Just get the large refill
vitipr171.00 |
07-21-2021, 06:30 AM | #29 |
891
Rep 869
I definitely second Sonax. Great product. I usually let it sit and then use the softest brushes I can find to agitate the inner sections of the rim. I haven’t coated my rims yet, but I just might when my M3 arrives. I’ve always found that a wipe down with some sort of non-greasy QD once dry, helps to improve appearance.
07-21-2021, 06:31 AM | #30 |
3007
Rep 2,745
Correct. Thanks for the write-up, looks like i need to try the Sonax.
Current inventory:
snareman9195.00 Limegrntaln13665.50 |
07-29-2021, 03:40 AM | #31 |
201
Rep 341
I use this plus Sonax.
Car Wheel Brush, Premium Automotive Detailer and Tire Brush Cleaning Kit for Bikes, Engines, Trucks, Boats, Equipment, Exhaust Tips, Premium Water-Powered Multi-Purpose Rim Brush from Brush Hero https://www.amazon.com/dp/B00Z7N7KGW...UTF8&psc=1
07-29-2021, 05:29 AM | #32 | |
2470
Rep 1,740
08-03-2021, 03:47 PM | #33 |
357
Rep 478
Another +1 for Sonax Wheel Cleaner Plus. I actually just picked up a gallon to refill my spray bottle. Hands down best wheel cleaner I have used. Make sure you use it on COOL to the touch wheels and you aren't washing the car in the sun... it will bake on quick and you dont want that. Also there are a few versions of the Sonax wheel cleaner... the Plus is the version you want.
08-17-2021, 07:22 PM | #34 |
305
Rep 868
Try Poorboys wheel cleaner. Make sure you buy enough dispensers as the fluid will clog the lines. Spray on and wash. No manual work. Have used on my F80 for 6 years.
https://www.autogeek.net/pbsrwc128.html
2022 BSM G80 Comp X-drive |
08-18-2021, 01:32 PM | #35 |
357
Rep 478
08-19-2021, 01:27 PM | #36 | |
309
Rep 228
I wish it was that easy.. Sonax Plus does not work for me... have to spray 2-3 & brush it to make it work. so it is basically a bottle per wash. sad...... |
08-19-2021, 01:38 PM | #37 |
9195
Rep 7,772
Yea, mine definitely required some agitation from a brush. Maybe if I had a power washer and power blower.
08-20-2021, 02:15 PM | #38 |
357
Rep 478
I use a power washer on a lower setting, maybe that has something to do with it. The other thing I do is ensure the wheels are cool to the touch and I let it sit on for about 3 minutes.
08-20-2021, 09:04 PM | #39 |
13666
Rep 7,023
Drives: 2022 DG/BLk xDrive M4C Wk 34
Pressure washer all day long. You just need to make sure you have the right nozzle size to go with the pressure washer. You dont need more than 1,000 PSI. Doesnt matter what pressure washer you have, the nozzles adjust the pressure of the jet.
Sonax wheel cleaner is good. I like P&S Brake Buster.
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
08-20-2021, 10:30 PM | #40 |
251
Rep 142
Pressure washer first then a quality wheel cleaner. Agitate with brush. Power wash off. Foam cannon entire car. Let sit 5 mins. Spray off. Soap with a wheel brush. Spray off. Wash rest of car. Dry. Vacuum. Windows. Interior. Quick drive around the neighborhood to get surface rust off. Clean that off with a microfiber towel. Take a shower. Go out to eat and start crying when you get to restaurant and wheels look like shit
13
jeffrc3m3200.50 M3-san252.50 Limegrntaln13665.50 revans1741.00 rdasari87.50 SimsimmaM3172.00 Laguna01///M31400.50 m4ml1894.00 egressive1.00 jetspeedb37.50 cubanbimmer3310.00 playswcars3687.50 dini_g80188.00 |
08-29-2021, 04:48 PM | #41 | |
13666
Rep 7,023
YT: G Dubyou |
08-29-2021, 04:49 PM | #42 |
9195
Rep 7,772
Unfortunately clean wheels aren't worth $8000 to me. And, I like the red calipers.
08-29-2021, 05:49 PM | #43 |
13666
Rep 7,023
Yeah, unfortunately, the OCD in me, hates brake dust. And I just like the bigger rotors, and I've never had a chance with other cars to even get them, so, for me, if I was going to build a car, I would spec everything I wanted. Kicking myself for not getting the Carbon Exterior package, but $103K was already giving me chest pains... But, now that the car is at the port, I think I want to call and add it, port installed.
YT: G Dubyou |
08-29-2021, 05:54 PM | #44 | |
9195
Rep 7,772
