BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Wiring OEM Reverse Camera Help - F48
      10-08-2023, 12:27 PM   #1
NemoNeil
Hi,
I manage to route the harness from the back boot to the front of the HU
I have a bunch of cables to finally connect but unsure where the yellow wires and green/red wires go.
From the packet, where the harness came in, there is a rough guide as per pic below where to connect the wires as i shown in below diagram.
but it doesnt say which pins the yellow wires connect to. or where the Green/Red wires connect to.
Pics below of my harness, and the wires i hae to connect.
Appreciate your help
X1 2017 F48
      10-08-2023, 05:15 PM   #2
678hug
Drives: F48 2.0i XLine
The twisted pair look like CAN bus wires. Hate to tell you but from the wiring diagram, it looks like they need connecting to the terminating resister block which is all the way back where you started in the boot.
      10-09-2023, 02:28 AM   #3
NemoNeil
Appreciate your respose.. crikey, didnt realise.,..
on the off chance, on the packet it came with... i just realised that the Yellow is written across two lines and for the F48 it states it should be connected to BDCBODY 8B no 44\43.
To my knowledge while searching the net, the BDCBODY is located under the glove box which i found... and the pics below shows various connections.. and im assuming where it says "8B" which is the CAN block 8 and if i look closely, the black connection is block 8...
Am i right or im talking jiberrish? or is your diagram the correct way connecting the twisted pair....
also the GREEN\RED wire needs Power ACC 5A, where should this go?
Thanks and appreciate your help...
      10-09-2023, 02:56 AM   #4
mrpingu
Norway
194
Although for mini, this thread contains some useful information including a F45/f46 retrofit guide from BMW
      10-09-2023, 04:01 AM   #5
NemoNeil
Not sure if I’m on the right track but after opening the wiring loom and looking for pins 43 and 44, they are already occupied.
So I don’t know where it says on the pack BDCBODY 8B stands CAN8 ?
Or shall I ignore the packet and follow the diagram posted by 678hug ?
Thanks for help so far.
      10-09-2023, 04:17 AM   #6
NemoNeil
To my theory… I also found OEM Camera install doc for F48…
https://mega.nz/file/9ggnDZJI#wVY2q-...TnR7IpWP4CbK88
Also references the twisted pair to connect to BDC
Now do I remove the existing wires or shall I tap into the wires?
      10-09-2023, 07:26 AM   #7
mrpingu
Norway
194
Great, then you also have the wire diagram.
Looks like these wires are already in place. You can double check using wire diagram on chapter 6 (page 12). Check both ends, on the BDC-side and the R3 bus-side then you know for sure.
Chapter 4 (page 8) is only applicable if you don't have bus R3 installed already, AFAIK most cars have both R2 and R3 installed from factory. Have yet to come across an car without it.
Using the wire diagram you can double check all wire connections and you can even scrible on it if you print it out.
For example the colors
      10-09-2023, 10:48 AM   #8
NemoNeil
Got to the boot passenger side but where will i find the R2 and R3 bus?
looks differnt to the adobe pics.
      10-09-2023, 11:28 AM   #9
NemoNeil
Driver side?
      10-09-2023, 12:33 PM   #10
NemoNeil
Just an FYI, I disconnected the existing wires on 43 and 44 on the BDC body and replaced with the twisted pairs as per packet instrauction and car started procuding light failures and stuff.. so immediately put back the BDC as it was and back to normal now..
So i take this as it doesnt go to the BDC or at that connection...
I assume it needs to go to the R2 or the R3 interface in the boot.
But where is this and which one?
any help
Thanks
      10-09-2023, 12:58 PM   #11
NemoNeil
any help
Thanks
Ok i found the R3 connection block...
I will try connections pins 9 and 22
      10-09-2023, 02:43 PM   #12
mrpingu
Norway
194
Yeah can be driverside if RHD, I have LHD vehicle and there it is passenger side :P
As you found it, you can just check with colors. White or Blue and Green on pin 9/22 (or 12/23 if vehicle produced after the date in the diagram).
As you have Blue & Green on pin 43 & 44 on BDC side you will most probably have the wires already installed, this way you can verify which R2 is which R3 is, R9 should have those wires on pin 9/22 (or 12/23 if vehilce produced after the date in the diagram)
      10-09-2023, 02:51 PM   #13
NemoNeil
So in my case I have yellow/white and solid yellow wires, would I install then on pins 9/22 on the R3 terminating resistor?
      10-09-2023, 02:54 PM   #14
mrpingu
Norway
194
No I don't think so as you already have it prewired from factory.
Edit:
No I don't think so as you already have it prewired from factory. (but verify, you know the pin numbers, colors.)
What is important is that you follow the total scheme.
So you have 2 CANBUS wires from BDC to R3 (this one is probably wired from factory (green & Blue)
BDC pin 43 & 44 (note the order)
R3 PIN 16 & 3 (note the order)
From R3 you have 2 CANBUS Wires to Camera (c* or a24, depending on which diagram)
R3 pin 22 & 9 (note the order)
C* pin 7 & 8 (note the order)
From Camera to headunit you have
C* pin 1,2 & 5 (note the order)
A42 (HU) pin 21, 24 & 23 (note the order)
From C* to PDC/PMA unit
C* pin4
B41 (PDC) pin 9
      10-09-2023, 03:20 PM   #15
NemoNeil
^^This is confimed in the pics above that pins 43/44 occupied by green/blue
this is my confussion as from my camera i have the twisted pair yellow & yellow\white wires... currently not going anywhere... so assuming it should go on the R3 pin 22 & 9 - picture below of the R3
^^ 100% confirmed 3 wires from Cam to HU are now connected.
C* pin4
B41 (PDC) pin 9
^^ this not to sure? The only wire i have remaing from my camera is the green/red which i assume goes to 5 amp fuse on the fuse block?
      10-09-2023, 04:30 PM   #16
mrpingu
Norway
194
Yes add the canbus wires (yellow and white to 9 & 22)
Well it seems that PMA & Reversing camera are on same powerline/fuse. So you just have tap into that wire somewhere.
Retrofit is instructions say to PMA, TIS diagram saus right to fuse but now you know these are shared power lines.
      10-10-2023, 11:21 AM   #17
NemoNeil
So wired everything as per instructions
I coded/activated icam_rvc using esys as per screenshot below.
HU_entrynav > camera_system >> ICAM (RVC).
I don't see a change in the screen just the same parking distance car in the middle.
Anything else I need to code. ?
Thanks
      10-10-2023, 11:49 AM   #18
mrpingu
Norway
194
Yes, when I calculate on my SVT I get the following changes
PMA2 module
rvc -> aktiv (01)
Ueberwachung_st_qu_rv -> aktiv (01)
HU_entrynav2
CAM_ECU -> wert_11 (0B)
MACRO_RV_C -> aktiv (01)
CAMERA_SYSTEM -> icam_rvc (02)
Why don’t you VO-code the car and modules?
Add 3AG to FA/VO and code PMA & Headunit
      10-10-2023, 12:14 PM   #19
NemoNeil
PMA2 module
rvc -> aktiv (01)
^^ All Activated
HU_entrynav2
^^ all active but couldnt find "CAM_ECU " ???
Add 3AG to FA/VO and code PMA & Headunit[/QUOTE]
^^ apologise never done this... do you perhaps share steps?
much appreciated.
below is what i now see additional items on the left display
      10-10-2023, 12:41 PM   #20
mrpingu
Norway
194
^^ All Activated
much appreciated.
below is what i now see additional items on the left display[/QUOTE]
I used this guide the first time: https://www.bimmerfest.com/threads/how-to-vo-coding.682418/
      10-10-2023, 01:09 PM   #21
NemoNeil
much appreciated.
I used this guide the first time: https://www.bimmerfest.com/threads/h...coding.682418/[/QUOTE]
Thanks, i'll do some reading around this...
i get the error when i read vcm... prob need to fix that first before i do VO Coding...
      10-10-2023, 01:14 PM   #22
mrpingu
Norway
194
No that is normal on x1, only read ECU works.
