08-11-2023, 05:21 AM | #45 |
32
Rep 61
I think it might be torque-related and not horsepower-related, else the 25d would use rubber mount too. maybe for >400Nm they use aluminum version and <400Nm is rubber version? just a little guess though.
08-15-2023, 03:14 AM | #46 | |
189
Rep 628
08-15-2023, 12:45 PM | #47 |
272
Rep 655
Glad you sorted it out.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
08-26-2023, 05:57 AM | #48 |
40
Rep 92
What kinda vibrations? When I turn on mines my idle seems weak then after the car warms up it dives fine. BMw say it’s a transmission software issue quoted me 350 for the fix.
09-19-2023, 07:46 PM | #49 |
32
Rep 61
Physical vibrations… not engine RPMs, but the engine physically moving, making vibration sounds in the engine bay. Some noted in more severe cases are vibration you can feel in the steering wheel. Usually comes from one side of the engine bay-the side that of the engine mount that has worn out.
09-23-2023, 07:24 AM | #50 | |
12
Rep 34
Engine mounts ok and auto box interrogation ok. They agreed there was minor vibration but kept it overnight and compared it when cold to another F48 which they said was similar. I did see the service bulletin for a gearbox software update but they said i didn't need it. The SB talks about vibration which even causes the car to stall when reverse or drive selected. Mine shows no difference when taken out of neutral and is a long way from that sort of level. At least i've got it recorded that i brought it in under warranty in case something appears at a later date when it is out of warranty. |
saphirschwarz.f4832.00 |
09-26-2023, 11:47 PM | #51 | |
32
Rep 61
