11-20-2020, 04:20 AM | #1 |
35
Rep 239
Sos system failure
I am getting this message once in a while. Sos system failure. I just visited the dealer, they told me the sos back up battery is dead. It has to be replaced. Total cost €600,- they say its the roof battery, so they have to take the whole roof liner out....
Car is 3 years old en one month out of warranty. They are going to give bmw a call to see if some warranty will cover this. I sure hope so, otherwise this will be my last bmw. Already had too many costs with this car |
11-21-2020, 11:32 AM | #2 | |
679
Rep 911
11-21-2020, 05:25 PM | #3 |
73
Rep 155
Google 'BMW SOS system failure' and get ready for a phone book of results to comb through. Feel free to pressure BMW to deal with it. If you reach the end of your rope on that path, here's the fix. Trust me, it's the only fix.
https://www.6post.com/forums/showthread.php?t=1690479 |
wcs2229170.50 AUS_Tin_Pusher23.00 |
11-23-2020, 01:34 AM | #4 | ||
Rep 51
11-24-2020, 05:08 AM | #5 |
35
Rep 239
Yes, it comes and goes. But it goes just like 1 in ten days. I also have another problem, the weather app is a lot of the time offline in the main menu. It just says 'no connection' but when i select it from the menu it works fine, when i go back to the main menu all of a sudden its there. This is from the same TCM box as the faulty battery. So maybe the whole box is broken?
11-27-2020, 10:08 AM | #7 |
119
Rep 264
Read above. Enter in that thread and you'll find how to code it out by using BimmerCode
2019 X3
2011 135i Alpine White DCT N55 All Stock Built on 10/10 Proud owner since 12/12. |
11-27-2020, 07:36 PM | #8 | |
119
Rep 264
2019 X3
11-27-2020, 11:56 PM | #9 |
73
Rep 155
Glad I could help. It's not inherent to X1s, it's all BMWs. I had the issue awhile back and pulled my hair out for days before finally stumbling onto that thread...had a feeling it was something I should have bookmarked.
CRuben09119.00 |
11-28-2020, 06:18 AM | #10 | |
679
Rep 911
Open the Bimmercode app and go to Instrument Cluster/Expert Mode/3301 CC_ID_Sperre/CC_ACTIVIERUNG_5/Custom Value. You should see 'FF' listed in Bytes 0 to 7. Scroll to Byte 5 and change it from FF to F7 and press 'Done'. In Bimmercode you can use expert mode search function to find location. |
CRuben09119.00 |
11-28-2020, 08:58 AM | #11 | ||
Rep 51
Appreciate your support. Regards AJ |
MJE60679.00 |
12-02-2020, 05:44 PM | #12 |
Rep 3
I had the same issue. When bought my connected drive app to remotely access my car for locking and unlocking.
So if u recently bought connected drive membership go to drive setting and press the data transfer button, its gonna take a couple of minutes but worked for me. Yours might be different but worth trying. |
03-09-2023, 10:13 AM | #13 |
Rep 11
Fix for SOS System Failure
There are so many reports of this problem on all BMWs and as dealerships are quoting mad money to fix it (I was quoted £800 to sort the problem) that there is now a a BMW specialist here in UK who are offering a fix it for a quarter of the cost.
I am sure I am like the majority of the owners/posters with this problem in that the problem starts with the SOS warning activating intermittently initially(I had periods when it stayed off for a week then came back again). 90% of the time the problem is down to the battery in the Telematics unit which seems to fail around 3-5 years from new. The genuine battery is around £50-60 here in uk, already expensive for a tiny battery the size of a matchbox but the majority of the costs are labour as in a lot of cases (definitely in an X1) the whole headliner needs removing as the Telematic unit is located under sharks fin aerial in roof!!! This is one of a number of problems I have experienced and the car is becoming a money pit so I reckon it will be gone pretty soon! Please contact me if you are in uk and need details of BMW specialist who is doing the cheap fix. |
11-10-2023, 05:01 AM | #15 |
Rep 2
04-12-2024, 11:04 AM | #18 |
194
Rep 648
I just did this repair, was 70 EUR for new battery and took me actually less time than anticipated. About 2 hours tops. Didn’t really pay attention when I started.
Before I started I saw recently a guy posted this video: https://m.youtube.com/watch?v=p7XUpQ9-DcY 2 comments to his approuch, loosening only the right side of the C/D-pillar is enough. You don’t need to remove the handles, rear middle seat belt and the roof light. Attached some pictures, because of other mod I already had the whole boot compartment stripped but as the video shows, that’s not needed. |
