12-27-2023, 12:11 AM | #1 |
Rep 11
HELP - X1 F48 Not responding after I-Level Update
Hi everyone!
I'm looking for some urgent help. Maybe someone can give me an idea of what could be happening or help me remotely. I try to do an I-level update to a X1 F48 with Ista but it showed a lot of errors while doing it. After finished, the car is not working. Some things work fine like mirrors and external lights, but the engine and idrive won't turn on. I tried to connect again to Ista but i'm having some errors as well. First is that Ista is not detecting the VIN so i have to manually put it. Them it appears to detect the vehicle but when running the vehicle tests, it shows the following message: "Switch off the ignition or deactivate PAD and insert the drivers seat belt into seat belt bucle". I try to follow those steps but nothing happens so i have to click cancel in Ista. Them Ista shows: The fault memory was checked for SAE fault codes. Further diagnosis communication with engine control unit is possible only after a terminal change. I carry out the steps that are shown in Ista and nothing happens either. And the last message that is shown in Ista is: "The integration levels of the vehicle could not be determined. Further order processing with programming is therefore not possible". Does anyone has experience something similiar and knows what i could do? *Attached there's a PDF with all the messages that Ista shows when running the vehicle tests. Last edited by judiobava; 12-27-2023 at 12:17 AM.. |
