BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Fuel Sensor Identification
      05-09-2020, 10:43 AM   #1
jamessfarnell
South Africa
20
Drives: F48 X1 SDrive18D 2020
Hi Guys,
Please assist me - I am looking to identify the name/function of the sensor in the picture below.
2016 X1 F48 Sdrive20d
The sensor is attached to the "Fuel Line In Engine Compartment" part number "13 53 8 514 114".
I just need to know what the sensor is doing and what it is called?
The sensor itself is leaking, and BMW want to replace the whole fuel line.
Tx
      05-09-2020, 10:47 AM   #2
Feddersen
Feddersen's Avatar
Denmark
451
Drives: X1 xDrive25i
www.bimmercat.com is your friend. Type in the part number or your vin number if you need to find a part.
https://bimmercat.com/bmw/en/parts/i...nt/13538514114 - according to the note the sensor checks the fuel temperature.
      05-10-2020, 02:10 PM   #3
jamessfarnell
South Africa
20
Found it!!
https://www.newtis.info/tisv2/a/en/e...essure/XrcdOYp
      04-17-2022, 02:48 PM   #4
Antoine13
Drives: X1 F48
Hello,
I have a similar issue, my fuel sensor is leaking
Jamessfarnell can you tell me how you fix the leak please ?
      05-31-2022, 03:39 AM   #5
pole1980
36
Drives: BMW X3 F25 & BMW X1 F48
Originally Posted by Antoine13 View Post
Hello,
Same issue on my wife's X1, that sensor is part of the whole fuel line, can't be fixed, the whole assembly has to be ordered and replaced (number 1 in the link). It's extremely stupid engineering, as the fuel actually travels down the wiring, from that sensor, directly into the ECU unit, it floods it and the ECU dies.
So, after replacing this, you should check if you have fuel on the ECU connector. If so, the ECU has to be opened and cleaned.
It's a fucking nightmare.
I wonder if jamessfarnell has fixed the issue without opening the ECU for cleaning.
      01-17-2024, 06:05 AM   #6
MU99
Drives: BMW F46 220xDrive
Hi Guys,
Just wanted to ask if 13538514114 part replacement resolved the issue with the fuel leakage or you did something extra to fully resolve the problem?
My sensor on 2nd series vehicle is also in diesel...
Thanks!
      01-17-2024, 06:09 AM   #7
jamessfarnell
South Africa
20
Hi All,
Its been a long time on this tread!
Solution was just to replace - BMW did this on warranty when car was still covered.
No fuel was in the ECU connection to my knowledge - no issues since then on this.
The item in question is a high-pressure fuel sensor.
      01-17-2024, 07:45 AM   #8
MU99
Thanks jamessfarnell for your quick reply.
I guess I have to start with particular part (13538514114) replacement and hope for the best.
pole1980 Let me know if your nightmare ended well and you resolved the problem? Thanks!
      02-10-2024, 05:32 AM   #9
pinco000
pinco000's Avatar
165
Drives: F48
Hi
I see you had the same problem. How did you solve it at the end?
I assume I need to buy the fuel line with the sensor coming with it, which is not a problem.
I would like to check if the DDE is flooded too but struggling to identify the location of it to check the connector if it has diesel on it.
Lastly, if the DDE has no leaks in, will this become a DIY job replacing the fuel line?
Thanks
PS: my car still drives etc so hoping it is not flooded but noticed while checking my car, that the MAF connector has diesel on it. Is this part of the fuel line. Do I need to buy the MAF sensor itself too?
Tags
fuel leak, fuel system
