BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Carly for BMW - on F48
      06-21-2016, 03:29 AM   #1
Geraner
Sweden
Drives: BMW X1 (F48) xDrive 2.0d
Hi,
Is anyone of you using the BMW Carly App?
Is this one already working for the F48 modells?
Anyone who has experiences with this App in general?
Thanks.
/Geraner
Current Cars: BMW X1 (F48) xDrive 2.0d, M-Sport, Automatic, Mineral White, Fuel consumption: Pictures are posted here.
Previous cars:
2012-05 - 2016-06 = BMW 118d (F20) M-Sport Package, Saphir-black metallic
2005-05 - 2012-05 = BMW 116i (E87), Havanna Brown
      06-21-2016, 09:17 AM   #2
X1PGK
27
Drives: X1 20d X Drive X Line 2016
I contacted them for advice and was told it's not available for the F48 yet. Told me to keep looking periodically.
      06-21-2016, 06:09 PM   #3
Ed_rx7
135
Drives: BMW M3 CP
So what does it do exactly?
      06-21-2016, 11:31 PM   #4
Geraner
Sweden
With this "Toy" you can read out fault codes from the control units, and perform some programming of functions in the car.
As I understand in some cars you can change for example whether you want to have the comfort access function enabled or not. Doing some simple setting changes by yourself, without going to the BMW workshop.
But the functions are very limited on specially newer modells.
I also sent them an e-mail and got the answer that it is depending on how fast they are getting access to a test-vehicle to check how compatible the existing codings are with the newer modells.
Some F-Modells are been released support for in the Android version of this software in June. But whether the new X1 F48 is already included can not be answered yet.
Just keep checking updates in the sofware from time to time.
I'm thinking about buying one of their Wifi-Adapters.
Previous cars:
      07-16-2016, 08:17 AM   #5
KPD
KPD's Avatar
171
Drives: F48 xDrive 20i xLine
Bumping this to see if you guys are aware of any updates. I'm not sure if their website is up to date.
I don't have a laptop and Carly seems to be the best option for iOS as far as I know.
      09-22-2016, 03:57 AM   #6
KPD
KPD's Avatar
171
Finally updated with coding support for F48. Update notes aren't that detailed: "Many new codings for all supported F-models, i.e. Engine Start Stop Memory, Welcome-Light and other rear light codings, iDrive codings (Video in motion) and many more…".
I'm away for a couple of days and don't want to order the dongle until after I'm back. Would be great to hear some feedback if anyone already has the dongle.
ttimbo281.50
      09-22-2016, 05:05 AM   #7
E90Fleet
South Africa
1312
Drives: BMW
Will try and get a F48 to test the app on it.
It works great on other models.
Glad the F48 is finally supported
BMW if you are reading, I need a job, Please.
KPD171.00
      09-22-2016, 05:40 AM   #8
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Am looking forward to hearing how you find this...it looks great on paper.
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      09-22-2016, 06:43 AM   #9
E90Fleet
South Africa
1312
Drives: BMW
It should work just as well as with other BMW models.
Makes coding easy and quick.
Have used it on many cars.
Will report back as soon as the F48 is brought over for me to check.
      09-22-2016, 08:25 AM   #10
E90Fleet
South Africa
1312
Drives: BMW
Slightly bad news
The app sees the F48 ECU's but gives me "the software version on the ECU is not compatible with the App yet".
This is a brand new late July 2016 build X1 that has the latest BMW software.
I had to update Esys to the latest versions to work on this car.
So Carly will probably work fine with older X1 with older BMW software, but its not working for coding on the very latest software yet.
Will see if I can arrange for a older X1 to test on.
Hopefully someone else on the forum has a older one to test aswell.
KPD171.00
      09-22-2016, 08:43 AM   #11
KPD
KPD's Avatar
171
Sounds like awesome news to me!! Picked up my car on launch day last October. Will buy a dongle from Amazon next week.
      09-22-2016, 08:45 AM   #12
Ed_rx7
135
Drives: BMW M3 CP
I was going to buy this..... keep us posted please
      09-22-2016, 10:13 AM   #13
civciv
Drives: X1 F48 Med. Blue
Bluetooth adapter is about 40 Euros. Beside this, do you also need to buy the Pro version of the app for coding?
      09-22-2016, 10:17 AM   #14
E90Fleet
South Africa
1312
Drives: BMW
Yes, you need the correct adapter for iOS (Apple)(wifi) or Android (Bluetooth) and you need to buy the Pro version of the app.
To register new batteries on cars you need to purchase another small once off licence in the app and also another if you want to code video in motion.
      09-22-2016, 12:14 PM   #15
Ed_rx7
135
Drives: BMW M3 CP
I thought the X11 didn't have DVD player up front?
      09-22-2016, 01:52 PM   #16
E90Fleet
South Africa
1312
Drives: BMW
Yes, I mentioned Video in Motion as the App carters for many E, F and X model BMW's
      09-22-2016, 02:46 PM   #17
Ed_rx7
135
Drives: BMW M3 CP
So how easy is coding with this thing?
      09-22-2016, 05:16 PM   #18
E90Fleet
South Africa
1312
Drives: BMW
Very
You just plug in the adapter and connect to it via the app.
Choose coding.
Read the current values per ECU.
Tap on the item you want to change
Tap code car.
Done
Once you are used to it it takes less than a minute to code something like Auto stop start memory from unlocking the car to being done.
Takes much longer to look through the options of what you can change than actually changing anything.
Just make sure the cars battery is well charged with a good charger attached or the engine running
Example on Youtube of iOS version coding in digital speedo
      09-23-2016, 12:52 AM   #19
Ed_rx7
135
Drives: BMW M3 CP
Thanks for the info.... looks pretty easy. Once they sort out the f48 compatibility for newer cars I'll get one. I take it you need the pro app to do coding?
Current Garage: )
MY18 BMW M3 CP....Mazda RX7 (750BHP)...Audi A1 Black Edition (180BHP)...2018 AUDI RS3 SOLD
BMW X1 XDRIVE 25D M Sport SOLD
      09-23-2016, 02:18 AM   #20
simon.
923
Drives: F48 25D mSport
Yes
      09-25-2016, 08:22 AM   #21
Ed_rx7
135
Drives: BMW M3 CP
Slightly bad news
Have you notified them of this?.... Did they give you a timeframe?
Current Garage: )
      09-27-2016, 04:51 AM   #22
AUS_Tin_Pusher
AUS_Tin_Pusher's Avatar
Australia
23
Drives: F48 X1 xDrive25i
I've been advised by Carly that currently they support modules up to March 2016 software versions, and that my May 2016 X1 vehicle build is too new.
Also that there are several months between a BMW software update and until they have the necessary info to code these, but that they are working on it.
It may be useful to subscribe to their newsletter.
ttimbo281.50
