BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) BMW X1 2017 - jerking on slow acceleratio / low rpm's
      01-11-2019, 12:41 PM   #23
Mushy007
56
Drives: X3 2D MH M Sport 2021
Originally Posted by thespido View Post
I started experiencing exactly the same power loss issues as the OP a few weeks ago, and it's been becoming gradually worse.
Yesterday evening, the car went through a crazy five-second period of conitinually trying to change gear and losing power before a drivetain error popped up and it reverted to limp mode to get me home.
This morning the car struggled to start, and cut out a few times before it finally started but again showed the drivetrain error and went straight to limp mode. It's booked in with the dealer for the week after next.
[Oct 2016 xDrive 20d]
This is the same as mine, I would calll BMW emergency, they will fix this on your drive, much quicker than your dealer, the revised egr should prevent this in the future too, he told me.
      01-21-2019, 02:37 PM   #24
Edtheted
Edtheted
Edtheted's Avatar
17
Drives: 2017 X1 1.8 sDrive xLine auto
Yes my 118d failed on my driveway the BMW emergency guy was there within 3 hours to replace the EGR valve but he said the car would require new firmware to go with it, which only the dealer could install.
Eddy Priest
      01-24-2019, 07:56 AM   #25
bmwx1guy
Drives: x1
just got the car back from BMW and yes the fault was also with the EGR valve.
      02-03-2019, 07:57 AM   #26
Colin DF753
10
Drives: X1 xline 20d
Had the same with mine about two years ago. Was told it was a faulty EGR valve and that it was quite a common issue. The valve was replaced and no issues since
      05-20-2020, 05:46 AM   #27
Forspe_13
Drives: BMW X2 M35i
I have a 2017 2.0d X1 xdrive with 15 000 km on the clock and the car has developed a fault where, if your cruising gently (on low RPM) and then gently accelerate the car hesitate and than sometimes jerk before it pulls away.
I have same problems as above mentioned - only btw 4th and 5th gear on low rpm, on low RPM then gently accelerate the car hesitate and than sometimes jerk before it pulls away.
Still don't know if it is gearbox or ERG ??
On high RPM no issues with gearbox, problem also somehow less when you are in SPORT mode, as as low RPM higher in this mode.
      05-20-2020, 02:22 PM   #28
X1_230d_First
Drives: bmw x1
Hello
I had same issue & BMW said transmission was broken.
BMW was gracious to say that they would pay for new transmission as I had only 50k miles (parts only) - which helped quite a lot for charges. Instead of paying 2200GBP, I ended paying 1k or so.
Good luck
      05-25-2020, 04:09 AM   #29
Fuzzzy
Romania
Drives: BMW X1 F48 20d
Check your EGR. My car had the same symptoms and needed an EGR replacement. I also was afraid of transmission problems, because it used to do so around 60-70 km/h, when slowly accelerating, but fortunately the problem was the EGR.
My car had 76.000 km at the moment of replacement.
      05-31-2020, 10:25 AM   #30
Vogit
93
Drives: X1 xDrive 20D xLine
Sounds like the problem I had with the EGR valve. Can't believe this hasn't been fixed yet.
      06-07-2020, 07:42 AM   #31
Wisly
Wisly's Avatar
Croatia
14
Drives: X1 18d
For past one month my 2016 X1 sdrive 18d started to hesitate and jerk to change gear when on low rpms, now I read here that it could be EGR valve. On higher rpms all is good. This happens in comfort mode. My scheduled service is in 6 moths, so I am not sure can I wait till then to check this or should go to service earlier. I have 50 000 km. If it is EGR valve, do I pay for it, how much does it cost aproximately or BMW covers the cost? Till January 2021 I have one more free service check and oil change from 5 year free service package.
      06-07-2020, 01:19 PM   #32
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
You cannot make every component 100% reliable. Eventually, some will fail.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      06-17-2020, 09:24 AM   #33
Forspe_13
Drives: BMW X2 M35i
EGR
Hi gents, finally went to BMW service and it was confirmed that EGR valve is defective, they changed and all went to normal, engine work much more smooth and back to normal, also notice that RPM are most stable at any speed.
To summarize - if you have delays when push accelerator at low RPM and response with delay, at some occasions it even look like problem with gearbox, most likely it is EGR valve fault, i also notice higher vibration of engine while idle, was nothing critical but still.. at service once i mentioned all problems, they have been even without checks conclude that it is EGR valve problem, and it is at 48000km only!!! so look like typical problem for that engine.
      06-17-2020, 09:32 AM   #34
Forspe_13
Drives: BMW X2 M35i
I drive the car about 3 weeks with defective EGR, even try to use premium diesel, which improve a bit, may be it was just my feeling, in general i cant say how long you will manage, first i have problem bwt 4-5 gear on AT, after problem also progress to 2nd gear when you pull at slow RPM, consumption was also higher, also notice that on high way was not easy to keep steady speed, was required to play with pedal to adjust it, in general i was able to drive still, but since my warranty will end up soon, i decided to approach service, may be try to claim that it is common problem, at least they should do discount, i did with my MINI Cooper when it was clear from forum that every second car of first generation have a problem with hydr pump for steering
      06-18-2020, 07:47 AM   #35
xlr8it
xlr8it's Avatar
Australia
30
Drives: F48 X1 20d, SLK55AMG
Had same problem with my 2016 XDrive 20D , the car is 4 years old now and out of warranty, took it to my local BMW dealer in Sydney yesterday and they confirmed it was the EGR valve, BMW has done a goodwill and supplied the parts for free , I did pay the diagnostic and labour fee which was AU$360, the car was ready this morning , all in all good service and result, the car drives like new again.
      09-05-2020, 02:35 PM   #36
aram1234
Drives: bmw x1
Mr
Bmw x1 2.0d , I have same issue
      07-25-2021, 11:41 PM   #37
chizoge
Drives: Man
cialis where to buy
<a href=http://cialiswwshop.com/>cialis for sale</a>
      07-26-2021, 06:51 PM   #38
CnSky
Ireland
331
Drives: BMW 530E 2017
Gezo I had the exact same problem, same model and year and it was solved by a recall to BMW where they install a new transmission software adaptation.
Hasn't returned since. Maybe this will help you with the dealer.
Note I didn't read the full conversation so sorry if you already solved this.
      08-11-2021, 05:29 PM   #39
chizoge
Drives: Man
cheapest cialis india
<a href=https://cialiswwshop.com/>cialis pills</a>
      08-30-2021, 11:52 AM   #40
jrveron
jrveron's Avatar
Argentina
272
Drives: 2023 X3 m40i
Question
I have a similar problem, but mine is a 2.0i petrol engine with 25,000 miles, and it's freaking me out
I have a JB+ and a K&N air intake, so my first step is to remove the JB+ and go back to OEM air intake. Then, the dealer will update the software for all the modules (transmission, etc.). And after that, make a full diagnosis.
The spark plugs were replaced 5,000 miles ago, so I think it could be the air sensor, transmission, or fuel pump (maybe?). What else could it be?
Have anyone experience this issue with a petrol engine?
Thanks!
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD
      08-30-2021, 10:03 PM   #41
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
Originally Posted by ttimbo View Post
Could be many things, but try this:
Steps...
1) hit start button once to turn on power (Don't start the engine)
2) then press the accelerator down to the floor for 5 sec
3) then hit start button once to turn off power
4) then remove foot from accelerator
5) then wait for 2 minutes
4) then start the engine like normal and see if that helps with the jerk and acceleration hesitation
This works on petrol engines
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      08-31-2021, 07:34 AM   #42
jrveron
jrveron's Avatar
Argentina
272
Thanks ttimbo,
I already did that, but it didn't help =/.
      08-31-2021, 11:57 AM   #43
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Originally Posted by jrveron View Post
Thanks ttimbo,
That is because it is a myth. It has been circulating for many many years and it gets posted on other forums. Even on the Audi/VW forums.
Many will tell you it is fact and they can feel it happen. It is the placebo effect.
The only way anyone can make a difference is have a full reset at the dealers.
      09-09-2021, 10:23 AM   #44
jrveron
jrveron's Avatar
Argentina
272
Thanks, Peter_R,
I just left my X1 with BMW to do a full update of all modules. I hope it helps with this issue and the other one I have, the vibration from a cold startup, but my gut tells me it's something else...
Anyway, I keep you posted.
