BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Spare tire (when you have non run flat tires)
      04-08-2019, 05:19 PM   #67
Proper
Proper's Avatar
100
Drives: X1 M-Sport
Originally Posted by karma_police View Post
Hello everyone.. I'm contemplating switching to non run flats on my new (to me) '16 X1. I just checked the under floor compartment where the spare tire kit would be secured but there is no hole in the liner. Now I'm not sure if there is actually a nut under there for the wing bolt to secure the kit to the floor. I'm not willing to slit open the liner to find out
Has anyone encountered this before? I'd really like to secure the kit down with the wing bolt and not bother with tie downs, etc.
I used the scissor jack to wedge the spare in there. Doesn't move one bit.
      03-11-2020, 05:55 PM   #68
alanzillo
Drives: X1 2016
Do you guys think a 135/80r17 would fit a X1 48?
      03-11-2020, 10:33 PM   #69
xlr8it
xlr8it's Avatar
Australia
30
Drives: F48 X1 20d, SLK55AMG
You need 155/80/17, 135 will be smaller in diameter to the rest of your wheels
      03-12-2020, 09:59 PM   #70
ttimbo
ttimbo's Avatar
282
Drives: F48 X1 25i AW; F20 M135i AW
135/90 x 17 is the size of the space saver temporary tyre that is on BMW's OEM spare wheel
Peugeot T9 308 GTi 270
Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182.
      03-14-2020, 02:47 PM   #71
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
Just to say that a Spacesaver is not an option with MSport Brakes.
Everthing goes to Entropy in this Age.
      03-14-2020, 11:40 PM   #72
NorcalMike
NorcalMike's Avatar
20
Drives: 2021 X5 M sport
I don’t know about the UK. But in the US M Sports have the exact same brakes as the X Lines. And you can absolutely use a space saver spare tire I have done it. If you research and it calls for the same brake pads on non M Sport I doubt you would have any problems. No matter what BMW is telling you. On my 335 the optional M Sport brakes were bigger than the regular brakes. But I even used a space saver on it I just had to use a spacer to clear the calipers.
      03-15-2020, 03:27 AM   #73
Beagler
75
Front calipers are bigger and Space saver would catch.
From BMW Uk
Good afternoon Graham
Thanks for getting back in touch.
I have checked your vehicle specifications and it shows that you have the M Sport braking system and this option is not compatible with the Space Saver storage.
I hope that this has answered your query but if I could be of any further assistance, please get back in touch.
Kind regards
Amani
We may send you an invitation to take part in our customer satisfaction survey – so you can let us know about your contact with us. You can opt out of this at any time by getting in touch with us or by using the opt-out link on your survey invitation.
BMW Group UK
Amani Al-Naggar
Customer Support Executive
BMW Customer Support
Summit ONE
Summit Avenue, Farnborough
Hampshire, GU14 0FB
Tel: +44 (0)800 325 6000
Tel: +44 (0) 800 3256 000
Mail to: customer.information@bmw.co.uk
URL: w
      07-09-2020, 12:17 PM   #74
ventjock
65
Drives: 2020 M340i
I'm about to do a cross country move and realized I should probably have a spare tire. I looked online for kits and found some ridiculous prices:
dealer $680 (just wheel and tire)
ModernSpare $415 with shipping
BimmerZone $396 with free shipping
sourced all the parts myself for under $240 including taxes and shipping
wheel $66.56 ECS tuning
https://www.ecstuning.com/b-genuine-...l/36116851507/
tire $98.61 TireRack
https://www.tirerack.com/tires/tires...rtnum=39R7KHV2
jack $24.97 Amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
wrench $26.17 Amazon
https://www.amazon.com/gp/product/B0...ace-2093936695
tote bag $12.69 Amazon
rubber stem valve including mounting the tire $6.91 at Firestone
I have a bunch of other stuff in the space next to the tire so it doesn't move around even with spirited driving
hope this is helpful to others looking to do the same and save some $$$
2016 F48 X1 -> 2020 G20 M340i
Appreciate 3
wcs2229170.50
BLIM3Y0.00
      07-10-2020, 02:08 PM   #75
jmhumr
49
Drives: 2017 BMW X1
Yep, I just a did the same thing. FYI, the same tire is a little cheaper on Amazon, and the OEM wrench is on eBay for $19.
      07-14-2020, 12:25 PM   #76
Larigos
Drives: BMW X1
Where is best for obtaining a spare tyre / jack etc in the uk? Got rid of the front run flats so need the spare now.
      09-07-2020, 10:23 PM   #77
trnguyen
76
Drives: BMW X2
Mercedes spare wheel
Has anyone considered or used Mercedes spare wheel with M Sport brakes?
Example (just the wheel, not the tire due the size): https://www.ebay.ca/itm/07-11-Merced...AAAOSwDHNfA101
I am not expert, but I Google it, the CB is 66.6mm and it's 5x112.
It should be fine on these aspects. The things that I am not sure is the offset to have enough room for the brakes. It's hard to say, but with the picture, the wheel shape seems to consider bigger brakes because it was for an AMG model.
The last thing is Mercedes seems to be ball/spherical seat. It will need a washer to convert to conical or M14x1.25 ball seat, not 1.5.
      09-07-2020, 11:01 PM   #78
Will Pwr
eM Power Me
Will Pwr's Avatar
749
Drives: '23 AW i4 eDrive40 M Sport
Another option to consider is using a spacer and if also needed, matching extended bolts (depends on thickness of spacer needed to clear the brakes). Something worth considering especially if one would have to explore covering to MB style bolts.
Will -
'23 Alpine White G26 ///i4 eDrive40 M Sport
'23 Brooklyn Grey G20 ///330e M Sport
'20 Alpine White F97 ///X3MC
'20 Alpine White F39 ///X2 M Sport X
      09-12-2020, 01:38 PM   #79
BLIM3Y
Drives: BMX X1 S281
X1 jack
Thanks for posting the parts and $.
Question. The cheap jack available like Amazon dont align with jack pads on X1.Are you planning on using a body jack point instead?
jack $24.97 Amazon
      09-12-2020, 04:40 PM   #80
Skyline2.0
137
Drives: 2018 BMW X1 xDrive
For spare tire changes in roadside scenario, I would not use the center jack points with a scissor jack. Would be dangerous and there's a high risk the car will slip off. Definitely much safer to use the jack pad points in line with the wheels.
If you want to get a non-BMW scissor jack, there are options where the jack's saddle will fit into the car's rectangular jack pad. Measure the opening on the jack pad and compare to the scissor jack's saddle before buying. I think Harbor Freight's scissor jack is a good alternative, but confirm saddle size first.
      09-12-2020, 06:21 PM   #81
Liwanji
22
Drives: 320i
when I ordered my 2020 X1 I specifically asked for non-runflats and added the space saver spare option for $150. non-runflats will save me couple hundred dollars when I need to replace them in the future, and $150 spare tire kit is worth the investment... but I do miss the storage room that is now occupied by the spare tire...
      09-14-2020, 08:48 PM   #82
trnguyen
76
Drives: BMW X2
I am not decided yet between MB spare wheel or the one from modernspare.com.
I am still looking, but if I end up to use MB spare wheel, I'll share the information.
The reason is I would like to go with 155/70R19 spare wheel versus the 135/80R18.
      09-14-2020, 09:06 PM   #83
Will Pwr
eM Power Me
Will Pwr's Avatar
749
Sounds good.... I'd be curious to see what you end up with.
Will -
      09-16-2020, 11:58 PM   #84
ventjock
65
Drives: 2020 M340i
I got this https://www.amazon.com/dp/B07R6M81LW/
      09-17-2020, 04:56 AM   #85
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
This is a common used item for fitting into the jacking points on later BMWs and used with many jacks to spread the load on the jack. Especially ones that have the circular jacking pad. I have had one many years and we call it a hockey puck in the UK.
2012 BMW 320d Sport (F31).
2013 BMW X3 xDrive 30d M Sport (F25).
2020 BMW X1 xDrive 2.0i MSport (F48).
2022 MB EQB 300 4MATIC AMG Line Premium
      10-06-2020, 01:33 PM   #86
Ridin'Dirty
Ridin'Dirty's Avatar
60
Drives: '93 'Beemer' R100r, '17 X1(S)
I picked up this scissor jack from Harbor Freight several months ago to help with tire rotation (along with the OEM scissor jack). Less than $20US w/coupon plus shipping. Fits into the cars jacking point box just fine.
      10-07-2020, 02:12 AM   #87
Peter_R
Air Vice Marshall
Peter_R's Avatar
256
Interestingly, I did the same and was advised that in the UK we cannot purchase an X1 with run-flats anymore so anyone ordering has the choice of a space-saver kit with jack(£150) or the mobility kit. My 2020 X1 xDrive 20i M Sport arrived 8 days ago with latest BMW* rated Continental PremiumContact 6 tyres.
      10-11-2020, 06:45 PM   #88
trnguyen
76
Drives: BMW X2
I made a plunge yesterday and bought a Mercedes spare wheel (no tire) 19x5.5 offset +13. I still have to look for a tire. I plan to go with the tire made for the BMW i3: 155/70/19 or 175/60/19. I need to figure out if the 175 will fit under the cargo area correctly.
For those interested, the i3 wheels seems to be an interesting alternative with the same bolt pattern, center bore and conical seat.
But for those with the M-sport brakes, I don't think the offset is enough.
The i3 wheel width is 5".
Another finding is the Audi Allroad 2016. On paper, it should fit our X1/X2. I am not sure tho about Audi center bore of 66.5mm and BMW is 66.6mm. Same converns for the M-sport brakes.
If someone wants to try, I find this today on Ebay: https://www.ebay.ca/itm/2016-AUDI-AL...M/133533024010
The collapsible tire that comes with it is the good size for our X1/X2: 175/55/19. It's 1.5% smaller (26.6" versus 27" diameter)
Too bad that I already paid for the Mercedes wheel. If not, I might go with this Audi because of the collapsible tire.
