07-19-2023, 09:28 PM | #23 | |
32
Rep 61
Attached here is a thread on the coilover shimmy for your reading pleasure https://f48.bimmerpost.com/forums/sh....php?t=1604373 |
07-20-2023, 02:24 AM | #24 | |
194
Rep 648
I won’t lower the vehicle, I drive a a SUV so I can drive some gravel roads without being stressed for damaging something underside |
07-21-2023, 10:51 AM | #26 |
273
Rep 659
Parts alone should be around $300-350, but labor will depend on the dealer. I won't expect it to be lower than $700 give it or take.
2023 X3 m40i Brooklyn Grey
2017 X1 sDrive M-Sport 2.0i (repro) - SOLD |
07-21-2023, 05:35 PM | #27 |
194
Rep 648
07-21-2023, 06:25 PM | #28 |
273
Rep 659
Yes, but you have another engine mount below. And on top of that, you need to consider the bolts and/or screws you will need to replace too.
07-25-2023, 10:17 AM | #29 |
194
Rep 648
Does one / do I need to replace the other mount together with the top mount? It seems the problems are only with the top mount.
07-25-2023, 10:50 AM | #30 |
273
Rep 659
Maybe not, but if I were you, I would definitely check it too.
07-27-2023, 07:40 PM | #31 |
32
Rep 61
If you’re doing it yourself, since you’re gonna be under the car doing it anyways might as well get both done so you won’t be pissed when the one you didn’t do earlier decides to retire. Save yourself some hassle of having to go underneath the car again next time
07-28-2023, 03:17 AM | #32 | |
194
Rep 648
Just makes me wondering if there are any better aftermarkets motor mounts that don't have the same problem dont want to replace that thing again after 40k km. Started making a list of aftermarket parts & manufacturers Vaico V20-2523 METZGER | 8054221 42464 01 LEMFÖRDER Mounting, engine Febi Bilstein |
07-30-2023, 08:20 PM | #33 | |
32
Rep 61
The ones you posted seem to be based off the old design… try to look for those based off the new design. Although I’m not sure where to find the new part number, realOEM ETK hasn’t been updated since 12/2019… Here’s a pic that compares the old vs new engine mount design. https://f48.bimmerpost.com/forums/sh...7&postcount=20 |
mrpingu193.50 |
07-31-2023, 04:04 AM | #34 | |
194
Rep 648
22118835566. This also comes up on my local dealer and most websites as latest part for my car However: According to this thread on other forum the JCW mounts can also be placed in X1. The only difference is the aluminium underbody it seems. Attached images from the internet. I think I am going to order this one and considering the PowerFlex Inserts while I am at it. Still undecided if I am going to do it my self or let a indy do it. Asked for a quote at one indy now. |
07-31-2023, 10:37 AM | #35 | |
273
Rep 659
Considering X1 vs. JCW piece, remember that the B48 on the X1 swings a lot so I would stick with the X1 version.
mrpingu193.50 |
07-31-2023, 11:20 AM | #36 | |
194
Rep 648
Seems to have 2022 catalog. Me too, as member of the BMW Car Club in my country I get 15% off ordering directly ar BMW, so then I always get to know the latest number anyway. I don’t follow your logic there. The JCW has 300+ hp so I would guess that mount is more sturdy because it will be probably be exposed to greater forces because of the output the motor can generate. Or do I totally miss the point here? Btw i have the wild 4-cyl diesel so B47 |
saphirschwarz.f4832.00 |
08-01-2023, 10:47 AM | #37 | |
273
Rep 659
As a side note, my x1 is close to 280hp, and with the standard x1 engine mounts, I need to replace them every ~20k km.
08-01-2023, 02:35 PM | #38 | |
194
Rep 648
If you look at this video: https://www.northamericanmotoring.com/forums/f55-f56-hatch-talk-2014/339406-f56-cooper-s-upper-engine-mount-replacement-5.html#post4595566 you see most movement is on top part anyway. The lower rubber part don’t seem to absorb that much. In terms of comfort is full rubber better as that absorbs more vibration. But I am most interested in not replacing them every year together with 2nd oil change I will probably get the PowerFlex inserts to increase the longevity of the mount… Would be nice to know if the JCW mount holds longer in your situation compared to the full rubber ones Do you replace them yourself or let dealer or other workshop do it? Just received a quote from a Indy that is not too bad with 300EUR in labour. Parts are another 280 EUR if I replace both mounts. So 580 EUR, not too bad but still opting to do it myself since this won’t be the first time probably… |
08-01-2023, 02:50 PM | #39 | |
273
Rep 659
08-02-2023, 09:38 PM | #40 | |
32
Rep 61
08-04-2023, 01:30 AM | #41 | |
194
Rep 648
X2 F39 M35i X2 F39 25d 1’ F40 M35i Mini Clubman JCW JCW GP3 |
08-08-2023, 11:52 PM | #42 |
32
Rep 61
hmmm, it is used on the X2 M35i and X2 25d as well… but not X1 25d? Or maybe that list isnt a comprehensive one… If it works on the F39, I dont see a reason why those mounts shouldn’t work on the F48 without problems
08-09-2023, 10:20 AM | #43 |
194
Rep 648
It is really weird as the X2 20d/20i has the same mount as F48 again... Only those higher output engines have with lower aluminium part
08-09-2023, 11:18 AM | #44 |
273
Rep 659
For Bertus87,
Here are the primary docs for replacing the transmission mounting. You need to remove the battery and the wheel cover to access it.
