06-24-2016, 09:45 AM | #1 |
137
Rep 1,328
Drives: 2017 Tesla Model X
Wheel compatibility for 2016 X1
Hello, I'm wondering if anyone knows what other BMW wheels are the same offset and bolt pattern as the 2016 X1? Because this vehicle is fairly new there aren't a lot of used wheels available but if the previous gen X1 or the current X3 have the same wheels then I may be able to pick up a winter set used. Thank you.
17 Tesla Model X 90D (I've been converted!)
PAST: 14 Tesla Model S P85D, 16 X1, 13 X5 M-sport, 04 M3 Cab, 08 E92 M3, 08 535xiT, 07 X5 4.8i, 06 E90 325i, 87 E30 325i, 85 E30 318i |
06-24-2016, 09:55 AM | #2 | |
93
Rep 251
06-24-2016, 02:50 PM | #3 | ||
923
Rep 2,559
06-24-2016, 08:58 PM | #4 |
Rep 40
F31 should have 72.56mm center bore. F48 uses 66.6mm bore. go to a tire shop and ask for hub rings so you can use the F31 rims.
offset might be different but you can ask the tire/wheel shop for info and please report back. i'm in the market for replica rims for my new F48 as well! |
06-25-2016, 01:21 AM | #5 |
Rep 8
I own the 2 series active tourer (F45) now and i ordered the X1.
So I hoped my winterwheels (589) could fit the X1. Sadly it doesn't because the centerbore is a bit smaller. I will have to look for a new set of winterwheels. |
06-25-2016, 01:56 AM | #6 | |
923
Rep 2,559
Serge. Did you read the above post? Spigot rings might well sort it so they fit. |
06-25-2016, 03:23 AM | #7 |
Rep 8
The wheels of my F45 has a smaller center than of the F48. So spigot rings do not work. If I want to fit my current winterwheels I will have to make the holes bigger to fit the F48..
06-25-2016, 01:09 PM | #8 |
137
Rep 1,328
Thanks for the info. Would be nice to hear if anyone successfully uses wheel from another BMW on their X1 and posts what spacers or hub-centric rings they used to make it work.
06-25-2016, 02:51 PM | #9 | |
923
Rep 2,559
06-25-2016, 06:16 PM | #10 | |
282
Rep 1,491
Peugeot T9 308 GTi 270 Renaultsport Megane 3 Trophy-R, Renault Clio Sport 182. |
