04-04-2023, 02:26 PM | #1 |
165
Rep 1,059
All possibĺe error thrown on the cluster
Hi guys,
I would appreciate if someone could help me with the above. I am very concerned as to what this is. Basically once a month I get the cluster with all faults displayed and then witjin 1-2 mins they all go away. Attaching picture. All help will be appreciated! |
04-04-2023, 02:59 PM | #2 |
188
Rep 618
How old is the battery?
04-05-2023, 12:45 AM | #4 |
188
Rep 618
If it is 5 years or older I would start there.
Most, if not all batteries have a production date printed somewhere. You could check that. Judging from the cluster you have a 2016 or 2017 model, maybe early 2018 so if it never have been replaced, good chance it’s the battery. |
pinco000164.50 |
04-07-2023, 01:23 PM | #5 |
165
Rep 1,059
04-14-2023, 04:23 PM | #7 |
188
Rep 618
I had the same this weekend but on the second car our little Ford Ka, throw a christmas tree of failure lights; Airbag failure, power steering failure etc... 3 days later it wouldn't start either. Replacing the battery tomorrow.
05-17-2023, 02:09 AM | #8 |
165
Rep 1,059
Hi guys, I replaced the battery a week ago and this morning all the errors returned.
Any other ideas? Could it be the alternator even though we checked the voltage with engine off ober 12V and with engine on over 14V. I am kinda lost here now. Please advise |
05-18-2023, 06:23 AM | #9 |
188
Rep 618
Did you already used an BMW specific OBD errorcode reader?
Still sounds like electrical issue to me. |
05-18-2023, 06:33 AM | #10 |
165
Rep 1,059
no as I dont have one. Put tge word out on FB forum if anyone has one and could help.
I was thinking here of alternator but the voltage readings are ok. Really out of ideas here |
05-18-2023, 09:20 AM | #11 | |
188
Rep 618
Best is to have ISTA for diagnostics but something like vGate iCar Pro in combination with CarScanner app for iOS https://apps.apple.com/no/app/car-scanner-elm-obd2/id1259933623?l=nb is more easy and gives possibility to read out lots of cars. |
05-19-2023, 07:18 PM | #13 |
Rep 3
Just had a similar issue on our 2019 X1. Dealer performed test and found a fault stored for the TCB (The Telematic Communication Box) battery. Replaced the TCB battery, cleared all the faults (we had random faults appear on dash) and verified no more faults on dash. Was informed that when this battery fails it draws power from car main battery to maintain limited function but still causes random error messages to appear.
Hope this helps! |
pinco000164.50 |
05-19-2023, 07:24 PM | #14 |
Rep 3
Some background on the TCB:
https://bmwspecialistreading.co.uk/s...service%20life. |
pinco000164.50 |
06-26-2023, 03:35 PM | #15 |
165
Rep 1,059
May I ask you if this has solved the problem. I replaced the battery and it comes up here and there. There is a week when there is no christmas tree lit up on my cluster only then for it to appear.
Do you how to access the battery? What sort of battery it is? I am quite ha dy with diy. Thanks |
09-17-2023, 11:37 AM | #17 |
165
Rep 1,059
guys, any ideas how to get to the sos battery?
I did run ista diagnostics and saw no error on the sos battery but still suspect it is causing my occasional array of errors. |
10-08-2023, 03:08 AM | #18 |
165
Rep 1,059
Hi guys, thought I will give here an update.
After no luck with various tests and Ista diagnostics, it turns out it was all about a USB key plugged in under the armrest. Removed it and never seen any sort off error. While I am veru glad this is over I need to find an alternative solution to play music stored on a drive. Maybe there is a USB drive that doesn't drag any voltage whike plugged in and engine off? Alternatively I can play music via bluetooth but that is not my preferred option as it will drain the phone battery very fast. Shame that on a such car as the F48 BMW cut the corner by not giving a internal drive. My old 60 plate E92 had one.. |
10-08-2023, 07:59 AM | #19 | |
188
Rep 618
Glad you found out but I would never have come up with that explanation…. A plugged in USB |
10-08-2023, 03:40 PM | #20 | |
165
Rep 1,059
It worked! I googled it afterwards and found out if you leave usb plugged in while engine is off, it will drain the battery. It is minimal but over long period of time it can cause these problems. Hope this thread helps someone tons of time and hassle. |
