01-02-2021, 06:38 AM | #705 | |
49
Rep 69
BMW 320d xDrive Touring M Sport(G21) Production Plant: Munich, Production Date: 2021-02-25 |
01-02-2021, 08:10 AM | #706 | |
76
Rep 155
I am new to BMW and to BimmerCode. I saw many use Bluetooth adapter, but I thought it would be better for me to go with the BMDiag Enet Wifi. I believe Wifi is more reliable than Bluetooth. The adapter I got also has the Ethernet port on it. Now I just need to get the Ethernet adapter for my phone to complete it. |
Takabo49.00 |
01-02-2021, 09:50 PM | #707 | |
171
Rep 313
I bought a Vgate iCar2 Wi-Fi and it works well for basic coding. Although I agree wifi is reliable, I make sure I am at a location without wifi interference from other devices and do config backups before coding changes. |
01-02-2021, 10:33 PM | #708 | |
76
Rep 155
And because I already have the BM Diag, I don't want to buy the Enet cable plus the adapter. I will probably buy only the adapter tho. Just in case someday I want to do do something more than basic coding. Also, coming from IT, I like to have these components nearby like in the past I had some Etherner PCI cards or USB Wifi Adapter then never used most of them (I didn't buy all of them tho). |
01-03-2021, 03:18 PM | #709 | |
Rep 16
https://www.amazon.ca/dp/B073XKQQQW Also look at the YoutTube at this guy descripted step by step instruction. I think bluetooth is more reliable connection to my iphone than WiFi since my car park out the house. I am waiting the bluetooth scanner that I ordered from Amazon and start my basic coding for my bmw. |
01-30-2021, 01:09 AM | #710 |
21
Rep 40
BMW E-sys coding for the f48 x1
Hi!
I own a BMW X1 F48 4/2019, SDrive 18d. I upgraded the existing 6.5 "display elements and the ID controller with: - Controller Touch control unit ECE-US 6582 9371374-01 SW: 01.0F.00 25.07.18 - touch controller 6582 9490069-01 SW: 02-0A-01 11/02/2018. - Central information display 8.8 "TOUCH 65508797400. Are the elements I listed appropriate for my vehicle due to the fact that the SW versions are from 2018 and the vehicle from 2019? Everything in the catalog fits, but I'm worried that version 1 and version 2 software are mentioned for the same model, as well as different hardware versions. I coded everything with Bimmercode and everything works. I want to permanently with e-sys the car configuration from S6UN to S6UP in VCM (CAFD injection and flashing), the reason is that I want my retrofit to be permanent and to be recognized by a BMW dealer whenever the car ECU software is updated. How does the CAFD Injection and Flashing coding procedure work? Thank you. |
01-30-2021, 04:15 AM | #711 | |
1804
Rep 3,070
Hi, As I already mentioned to your email hardware could be different therefore HWEL won't match. Just stick what you have now. Changing 6UN to 6UP may couse your car unable to flash by dealer.
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
zeljko221.00 |
01-30-2021, 07:04 AM | #712 | |
21
Rep 40
All parts are according to the catalog for my vehicle and VIN number. Do you think, for example, that the touch controller 9490069-01 would be inappropriate if a touch controller 9490069-02 was installed at the time of purchase? I note that I did all the coding with bimmercode and everything works perfectly. |
01-30-2021, 12:20 PM | #713 | |
1804
Rep 3,070
zeljko221.00 |
01-31-2021, 12:04 PM | #714 |
Rep 2
Hi folks, have been trying to code my 2016 X1 18D Auto so that I don't have to press the brake to start engine, I've searched posts and tried setting TCM_STARTLOCK_BRAKE to nicht_aktiv and also TCM_STARTLOCK_DRIVINGREADINESS but all it does is not allow me to start engine. Have tried 2 presses one long press etc. Does anyone know what else I need to do? I noticed TCM_STARTLOCK_DIESEL and TCM_KL15_OFF_ELECDRRD_OFF but no idea what they are for? Thanks.
01-31-2021, 06:30 PM | #715 | |
681
Rep 913
Welcome to the forum. I will be brutally honest, your post frightens me and you are asking to “brick” your car. I would never go into expert mode and “try out” coding options, 99% of the time they will not do want is wanted and can just be reversed but there is 1% where they can trigger significant issues. A common disaster is to trigger a feature which requires an fsc code, which you will not have and your head unit will lock. I can list many more scenarios, usually people end up begging coders on bimmerfest coding forum to rescue them (which wore thin a few years ago). Stephan Gauch (Bimmercode) started to hide more dangerous parameters lurking in the advanced mode but don’t bank on safety, he posts a disclaimer for a reason May I kindly suggest that in future you ask if anyone knows a solution before you “bravely go where no....” One option is to search the expert forum for fdl code changes needed. If that fails you could ask (do not mention Bimmercode unless it is a Bimmercode thread) , give your car model - F48 and HU - yours is probably Entrynav, the reason for detail is it gives the impression you know what you are doing, they will not bother replying otherwise. If you get the answer you may then be able to find the (Fdl) parameters in Bimmercode. Sorry if this sounds harsh but I am genuinely trying to help. Last edited by MJE60; 01-31-2021 at 06:36 PM.. |
02-01-2021, 04:28 AM | #716 |
21
Rep 40
Hi!
Thanks to everyone who helped me clarify the coding with e-sys for the BMW X1 F48 with 6UNA navigation. Not to burden some forum members with additional questions I have one question for everyone so let someone answer me. I realized that my 6UNA configuration was not designed to upgrade a larger display with a touch function as well as a touch controller and that the final CAFD Injection and Flashing encoding would report errors and would not accept encoding. I'm wondering if the FDL encoding (replacement in the SALAPE element 6UN with 6UP + write FA) would be error-free and if that would be enough for the new firmware not to delete those encodings in the service when upgrading the ECU or to give up everything and leave the bimmercode encoding where everything works ok. Thank you all. Last edited by zeljko2; 02-03-2021 at 11:37 AM.. |
02-01-2021, 05:30 AM | #717 | |
Rep 2
MJE60681.00 |
03-30-2021, 08:58 AM | #719 |
Rep 4
Hi, I was able to code several things on my 2016 X1 F48, but unsuccessful with coding of possibility to configure the SPORT driving mode (Drivetrain, Chassis, Drivetrain&Chassis). Anybody to help? Thank you
01-13-2022, 06:10 AM | #720 |
Rep 18
Hello guys, I own 2017 x1 from US, how to code front LED lights form US to EU. I mean original US lights are still in my vehicle what I want to do is to change their mode from symmetrical US to European non symmetrical
01-14-2022, 03:32 AM | #721 | |
2376
Rep 8,364
Actual changes depending on hardware. |
02-15-2022, 01:28 AM | #722 |
Rep 8
hello guys, i new here and no experience about coding or programming.
i have 2019 X1 F48 after flooded. i already replace BDC and the the other. after programming BDC control unit, i have some problem DME program abort. i tried to fix it but i dont have psdz data full for 18-03-541 ilevel. missing SWEs detail: DME_BAC3_0x12 btld_00003e72-001_007_001 swfl_00003e7d-030_110_003 swfk_00004d6e-030_110_107 sorry for my description, i hope you all understand. i need help to fix it or can anyone to check it. thanks |
02-15-2022, 07:49 AM | #723 | |
204
Rep 818
Good luck! |
02-15-2022, 02:49 PM | #725 |
47
Rep 231
2018 BMW X1 B48 2 liter xdrive purchased in Feb 2019. I have a local guy that does programming and I did the following:
1. Mirrors closed with Key FOB or convenience access from door handle. 2. Turned off start/stop at engine on. Can turn it on manually. 3. LED Fogs and LED rear tails and turns and front turns (eliminates blinking/strobe) 3. Open or closed all windows and sunroof with key FOB or convenience access from holding door handle for longer than just to open doors. 4. M power logo at start up including on HUD display. 5. Extra options on the digital display in the dash. 6.Got rid of idrive disclaimer page on start up. 7.Got text messages to show full message rather than 3 lines. 8. Fog lights can now be turned on while park lights on. 9. Changed Angel Eye Brightness when headlamps on to 50% 10. Door handle LEDs light up when engaged in Reverse 11. Fog Lights remain on when high beams are active. Can be turned off manually... 12. Added the vehicle’s current speed to the BC cycle list (Displays on KOMBI screen). For an extra $500 he installed a pre/mapped/canned ECU stage 1 which added HP and TQ. I have a BMS intake and he coded it in so that there's no ECU error. |
02-17-2022, 09:36 AM | #726 | |
Rep 8
